uraksha2
Mar 07, 2024Follower
RAXE300 Site to Site VPN?
I have two RAXE300 routers. I would like to setup a Site to Site OpenVPN connection between the two routers. I figure I will need to use TAP mode.
I know how to setup one of the routers as the VPN Server but how do I (if possible) setup the second router to act as the client router to connect to the first (server) router to establish the TAP tunnel?
Is there a different way to accomplish the objective with these routers?
1 Reply
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
