wildcatswon
May 11, 2021Tutor
RBK13 satelite add-on options?
We currently have an RBK13 Orbi mesh system at home but need to add 2-3 more satelites as the block walls of our Florida home are not very Wi-Fi friendly and must expand our system. I was curious if...
- May 11, 2021
You can add on the satellites but the router doesn't function as a satellite.
May 11, 2021Guru - Experienced User
wildcatswon
May 11, 2021Tutor
Thanks for the help. I believe it still makes $$ sense to buy the system as it makes the satelites cheaper than buying them alone, plus I would have the extra router in case the other died on me.
