tfsquare
Sep 06, 2020Aspirant
RBK20 Speed Reduction from 1000mbps to 200mbps after Passing through Orbi Router
I have started streaming and is internet speed demanding. I found that eventhough my notebook is connected to the internet via lan cable [cat 6] to the router and the router to the service provid...
- Sep 07, 2020
If your modem really is a modem/router, then you should see if you can find instructions on how to use it in "bridge" (modem only) mode.
If you cannot do that, then you can see if it works if you put the RBK20 into wireless access point (AP) mode.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
michaelkenward
Sep 07, 2020Guru - Experienced User
Support | NETGEAR
tfsquare
Sep 18, 2020Aspirant
Thank you so so much!
I switch the RBK20 to AP mode and it works perfectly with 8xxmbps now.
