ClFan
May 29, 2021Follower
RBK50 — Orbi AC3000 Tri-band WiFi System - Use of extenders
Hello, I have a Orbii AC3000 (RBK50) with one satelite. I want to extend the range in the house by using a wall plug in extender. When I use an extender and I assign the same name to the extender s...
May 30, 2021Guru
You can do that but it might not function like the orbi system as they don't integrate like an orbi satellite.
The EX7500/EX7700/EX8000 work fairly similar. The other extenders do work but again, they probably won't roam the same.
There is an orbi plugin that is compatible. The RBW30
