Smegster
Oct 10, 2021Aspirant
RBK50 - can I connect the RBR50 router wirelessly to the modem/router from my internet provider?
Hi all, not too tech savvy so any help appreciated! At the moment I have my RBR50 router connected to the router/modem that my internet service provider has supplied, using the yellow "internet" por...
michaelkenward
Oct 11, 2021Guru - Experienced User
Smegster wrote:
At the moment I have my RBR50 router connected to the router/modem that my internet service provider has supplied, using the yellow "internet" port and an ethernet cable.
That photo is very helpful. It shows that you have two routers.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- SmegsterOct 12, 2021Aspirant
Thank you so much for your quick reply michaelkenward that's great and given me a really good direction to move towards.
I think that putting the Orbi router into AP mode will be the way ahead and the set up of this seems relatively easy, connecting to the existing router to set it up.
From all the tutorials and searching I've done on this, it seems that the Orbi router will need to remain connected via a cable to the existing router, is that true...? Ideally what I want is a solution where the Orbi router connects wirelessly to the regular router as I would like to put it on a floor above, and then the Orbi satellite on a floor above that again...
Not sure if that's possible though.
Thanks again for your advice!
Greg
- michaelkenwardOct 12, 2021Guru - Experienced User
In AP mode yes.
My way around this is to use the house's Powerline Ethernet on the mains circuit to connect the (R7800) router to an Orbi in AP mode.
Beats wifi repeater mode, if the Orbi and your anonymous router support it. Wifi is flaky and can be slower than decent Powerline.
But that may depend on the speed of your Internet service. I am on DSL.
