scrivprim
Dec 15, 2020Aspirant
RBR10 keeps dropping out - can't get latest firmware
Hi! I have an RBR10 connected to a Sky router. Has been perfect for months. Last week I upgraded to ultrafast (fibre to property). Sky router hasn't changed (although no longer used as a modem - ...
- Dec 18, 2020
Solved!
After messing around with wifi channels, switching mides etc.......... just totally factory reset eveything I coud get my hands on and started from scratch - Sky router, Sky Q, Sky mini, Orbi router and satellites etc.. and now works again. Can't be sure - but the order I did it in suggests it was the Sky equipment caused the issue.
scrivprim
Dec 18, 2020Aspirant
Solved!
