burge
Nov 05, 2020Aspirant
RBR20 dropping PS/4 connection
I have a RBR20 Orbi with an RBR30 satellite. We have two PS/4s in the house. One connects to the RBR20, the other to the RBR30. The one connected to the RBR30 consistently drops the connection during...
burge
Nov 06, 2020Aspirant
More info: I have an xfinity modem where I shut off all the wifi to it. I have the orbi set up in access point mode (switched over to see if it would work better, no change).
I'm broadcasting both 2.4 & 5Gz networks. I have WMM enabled. Enable Daisy-Change Topology is checked.
Implicit beamforming - checked
MU-MIMO - checked
Fast Roaming - checked.
burge
Nov 17, 2020Aspirant
Separated the guest network out to 2.4. Dropped the 2.4 Gz network to transmit at 50%. Seems more stable, but connections still drop.
