Beachbound
Apr 02, 2021Aspirant
RBR20 router won't allow TV's to connect
My RBR20 Router is successfully sending an extremely strong signal throughout the house, however, it won't allow my Smart Tv's with Firesticks to connect. They all see the router but it says "No inte...
Apr 02, 2021Guru - Experienced User
what modem/gateway is the orbi connected to?
- BeachboundApr 05, 2021Aspirant
plemans (Guru), It is a Spectrum Sagemcom RAc2v1s. Last letter might be a 5.
- plemansApr 06, 2021Guru - Experienced User
that sagemcom is a router.
Connecting 2 routers in series can cause issues. It causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Is there a reason you're going sagemcom--->netgear?
