euroegyptn's avatar
euroegyptn
Follower
Mar 26, 2021
RBR40 and 2 RBS20 - WiFi issues (How to optimize my Orbi Network for best performance?)
Hello,
I was hoping to get some help or feedback with my Orbi AC2200 Tri-Band Mesh Wi-Fi System. I currently have one RBR40 Router and 2 RBS20 Satellites. I live in a 2,300 sq ft. townhouse.
My main issue is most of my devices (2.4GHz and 5GHz ) are either connected most of the time to the main RBR40 router or if any of the devices do end up connecting to the other 2 satellites they connect on 2.4GHz instead of 5GHz, for example iPhone, iPad, Apple TV, etc,...
I have been searching online for months and I have tried different suggestions/recommecndations on tweaking the settings but I still have no luck. I also tried rebooting the main router, satellites, moving them to different locations around the house (same level) but still no luck.
My question is what is the optimial settings to make the Orbi connect to the devices that are nearby instead of the main router or forcing it to connect to 5GHZ instead of 2.4GHz? This has been severly impacting the network in the house causing slow speeds.
RBR40 Router: https://www.netgear.com/support/product/rbr40.aspx
RBS20 Satellite: https://www.netgear.com/support/product/RBS20.aspx
Current setup and configs:
1. RBR40 router in the basement
2. One RBS20 Satellite in the second level (Living/Kitchen)
3. One RBS20 Satellite in the third level (Bedroom)
4. Both Satellite are connected to the main router via wireless backhaul
*** RBR40 and RBS20 are all ruunning on Software V2.6.2.104 ***
Channel Settings:
  • 2.4GHz Channel: 1
  • 5GHz Channel: 48
Advanced Wireless Settings (2.4GHz b/g/n):
  • WMM (WiFi Multimedia): Enabled
  • Enable 20/40Mhz Coexistence: Disabled
  • CTS/RTS Threshold (1-2347): 2347
  • Preamble Mode: Automatic
  • Transmit Power Control: 50%
Advanced Wireless Settings (5GHz 802.11a/n/ac):
  • Transmit Power Control: 100%
  • Daisy Chain Topology: Enabled
  • MU-MIMO: Enabled
  • Implicit Beam-forming: Enabled
  • Fast Roaming: Enabled
I would greatly apprecaite any help or feedback.
No RepliesBe the first to reply
