konagal's avatar
konagal
RBR50 and satellites compatibility with VPN
I have Orbi RBR50 with 3 satellites one is an outdoor satellite. This router apparently is NOT VPN compatible. I need to purchase one that IS VPN compatible. I have around 10 devices attached to it. However, my VPN provider recommends these three routers
Linksys WRT3200ACM,  Netgear R6700v3 Netgear R7000
ONLY Linksys can handle over 8 devices, the others only 4-7.
Which is recommended and I read that ONLY the OUTDOOR SATELLITE set in extender mode will be compatible with the other routers. WHICH routers are compatible?
Also must be compatible with SPECTRUM
No RepliesBe the first to reply
