GreyBeard1948
Apr 08, 2021Aspirant
Rbr50 and two satellites
Whenever I try to see if there are any firmware updates I get an error message instead of the message stating your firmware is up to date. Any suggestions as to why I keep getting the error message. I...
Apr 08, 2021Guru - Experienced User
what modem/gateway do you have?
What actual firmware version are you on?
You can view/download the latest firmware on the support site.
https://www.netgear.com/support/product/RBR50
the manual walks you through manually updating as well. If you go this route, do the satellites first.
- GreyBeard1948Apr 10, 2021AspirantThe router firmware is v2.7.2.104
I am not sure what you mean about modem/ gateway but we use point broadband as our internet provider as we stream our television viewing. One of the satellites is the Rbs 40v Orbi voice. I am not sure if that would cause the error message all the time.- plemansApr 10, 2021Guru - Experienced User
You are up to date (as of today) but it might not be connecting to the server properly if you have a double nat issue.
It why i was curious about your modem/gateway
- GreyBeard1948Apr 10, 2021AspirantThank you for trying to help but I do not understand what double mat is and also gateway/modem. I would just like to know how to fix my problems.
Thanks
