GreyBeard1948
Apr 08, 2021Aspirant
Rbr50 and two satellites
Whenever I try to see if there are any firmware updates I get an error message instead of the message stating your firmware is up to date. Any suggestions as to why I keep getting the error message. I...
GreyBeard1948
Apr 10, 2021Aspirant
Thank you for trying to help but I do not understand what double mat is and also gateway/modem. I would just like to know how to fix my problems.
Thanks
Thanks
Apr 11, 2021Guru - Experienced User
Its tough to help with minimal info. You wouldn't expect your mechnic to fix your car with only the info of "its a ford car" and when the machanic asks what motor is in is is told "its a motor just tell me whats wrong".
It doesn't work like that. There isn't a simple "fix it" button that corrects all problems.
