jpiechoski
Apr 26, 2023Initiate
RBR50 Firmware Version V2.1.2.18 will not allow me to update the firmware.
RBR50 Firmware Version V2.1.2.18 will not allow me to update the firmware. Trying to upload file RBR50-V2.7.5.4.img downloaded from the Netgear website on 4/26/23. When hitting the upload butt...
- Apr 26, 2023
install version 2.2.1.212 first.
install it to the satellites and then the router.
This version expanded the firmware provisioning so newer (bigger) versions could be installed.
jpiechoski
Thank you. I was looking at earlier versions but didn't go back quite that far.
Thanks again!
Apr 26, 2023Guru - Experienced User
Glad it worked!
