SunnyGuy53's avatar
SunnyGuy53
RBR50 hangs on 2.7.1.60 FW update
I just updated my RBS50 (satellite) from v2.5.2.4 to v2.7.1.60 just fine, but when I tried to do the same to the RBR50 router, it just continues to show the spinning hourglass, (for over an hour now).
How do I restore sanity, or is the router bricked?
I suppose I could do a factory reset. Or is there something simpler?
Thanks.
Mark
  • You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Orbi - NETGEAR Communities
  • The something simpler was that I logged onto the RBR50 router over WiFi, saw that it claimed to be running v2.7.1.60, and rebooted the sucker.
    So far, all appears well.
    Mark S.
    • michaelkenward's avatar
      michaelkenward
