RGPvan
Mar 20, 2021Guide
RBR50 keeps dropping internet connection to devices, requires reboot every 12 hours
Since going to the latest firmware, v2.7.2.104, some devices on my network like cell phones, both Android and IOS show they are connected via wi-fi but don't have an internet connection. Streaming d...
- Mar 25, 2021I have been dealing with the same problem with firmware 2.7.2.104. I turned off the traffic meter and my wifi came back on almost immediately. I saw this fix elsewhere on this site. Hopefully they will fix this firmware issues. My tvs would work, but phones and tablets would lose connection every day until power cycle. Now with traffic meter off so far it is working.
jonnymack2020
Mar 23, 2021Tutor
Not sure if the fix suggested here will work, I just tried it but have been having the same issues as well. Something wonky in the traffic meter. Looks like there was actual NetGear commentary which would be nice if they stickied a response for us all to find instead of combing through hoping to find wisdom. If not helpful, apologies.
https://community.netgear.com/t5/Orbi/Orb-RB40-MAJOR-DNS-Issue/td-p/2071117/page/2
- hisselfMar 23, 2021Star
Thank you. I just turned it off, we will see if it helps.
It would be nice if Netgear would provide help with these problems - the same problem has been posted here for several years. We (the Community) do not work for Netgear, why should we be doing their customer service?
- RGPvanMar 23, 2021Guide
Giving the referenced fix a try. Will let you know if it helps. Thank you!
- jonnymack2020Mar 25, 2021Tutor
Agreed, I haven't had the dropping issue since I turned it off. will keep monitoring it but hopeful which I could not say a week ago.
