philtully
Aug 15, 2021Aspirant
RBR50 RBS50 backhaul can daisy chain and star combined?
I currently have an RBR50 with 2 RBS50's with wired backhaul. Due to the physical configuration of my house we still have a gap in coverage. I would like to add a 3rd RBS50 into the configuration. The 2 current satelites are wired direct from the RBR50, is it possible to add the 3rd RBS50 into the configuration daisy chained from one of the current RBS50's or do I have to run a cable from the RBR50?
1 Reply
- olympos1625NETGEAR Employee Retired
Hi philtully,
Welcome to NETGEAR Community!
Thank you for reaching out. You may connect the 3rd satellite to the nearest Orbi satellite via ethernet cable. You may check this link
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
