The_Zyph
Mar 05, 2021Aspirant
RBR50 router appears to be bricked after factory reset
I am passing on my RBR50 and 3 satellites to a relative, so I performed a factory reset on all of the devices in preparation for that. When trying to install them in the new house, though, I cannot ...
antinode
Mar 05, 2021Guru
> [...] I cannot get anything other than a flashing white ring on the
> RBR50. [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] I set my ethernet adapter [...]
That's part of the TFTP scheme, so you're on the way. (It's critical
if the router is dead enough that its DHCP server isn't working.)
> [...] I've seen many posts/docs [...]
Thanks for the helpful links.
My Orbi experience/expertise is nil, but if the flashing lights don't
match the published descriptions, then you might want to do some
experimental variation in the timing of the "PUT" command in the TFTP
procedure.
> [...] I have tried all 3 ethernet ports [...]
Any of the LAN ports should work as well as any other LAN port.
