khudsn7's avatar
Jul 07, 2018
RBR50 stopped working this morning
RBR50 and RBS50 This morning I got up and immediately noticed the purple light flashing on my satilite.  I checked my computer and had no network connection to orbi RBR50.  After trying everything ...
  • antinode's avatar
    Jul 07, 2018
    > [...] did a factory re-boot(put small pin into hole for over 10
    > seconds and solid orange light turned to blinking.) [...]
       That's a settings "reset", not a simple "re-boot".
    > [...] now, I see orbi41 listed in dropdown of all networks available.
    > But now, it says password is incorrect.  Before you suggest this, I have
    > already tried several times the default password, "password".  [...]
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Types of
    Logins" and "Factory Settings".  "password" is not the default
    password/passphrase for a wireless network connection.
    > [...] will NOT take anything I put into it.
       Think for a moment about how little useful information that
    non-description conveys to the non-psychics in your audience.
