Ali-OB's avatar
Ali-OB
RBR50/
RBR50v2 Can I buy an additional satellite to plug into this?
  • plemans's avatar
    May 10, 2021
    yes you can.
    Compatible models are:
    RBS20
    RBW30
    RBS40
    RBS40V
    RBS50
    RBS50Y
    Keep in mind, only the 50 series support the full 1733mpbs backhaul. The other series only use a 866mbps backhaul.
