Rhmorgan67
May 01, 2021Guide
RBR850 3.2.18.1 - No communication with ISP, drops every 2 hours
In January 2021 my RBR850 updated firware to version 3.2.16.22. Every two hours my router would disconnect and I would have to unplug, and reboot. I checked with my ISP and every 2 hours when their s...
Rhmorgan67
May 01, 2021Guide
I've been on with Netgear support, we did a factory reset of the modem and the little box does not exist on my screen. There should be a box that says, "automatic updates" or something like that, but there isn't. They said when first setting up the router, I may have chosen auto updates and so the box disappeared, but doing a factory reset should have made the box return - but it didn't. They are now supposed to call me back in 2-3 hours...
No1Mportnt
May 01, 2021Luminary
Not sure why the box is not there but I do know on mine you can select your choice and the other selection is still there. Hopefully, they will have the answer when the call you back.
- Rhmorgan67May 01, 2021Guide
GearHead tech support doesn't know how to fix this. First guy said to go to Backup Settings and choose "erase" to reset to factory default settings. He thought that would make the box that says, "auto updates" appear again in the Firmware Update section. If it reappeared I would be able to uncheck the box and only allow for manual updates. However, the little box did not appear. He said he would call me in 2-3 hours. He never called. 6 hours later I called and spoke to a woman. She had me change the 2.4 GHZ channel to "9", keep the 5GHZ at 48 and change the WAN MTU from 1500 to 1147. Nothing changed. I am now on my 3rd technical support call. He just came on the line and said he has to check with the "L2" Department. I asked him what that meant and he said it's "Level 2 Tech Support." I'm on hold to see what he comes back with...
Netgear has officially disabled the ability to refuse automatic firmware updates. So, that means if they screw up their newest firmware - there's nothing you can do about it. Even though you can "manually" install an older version, it will upload the new version while you sleep at night to make sure you wake up with the same problem!
