wififast's avatar
wififast
RBR850 App Not Supported Product
Updated to Version 2.9.5.14 of the Orbi - WiFi System App. Updated firmware for the RBR850 Router. Everything was working great before the firmware update. When I try to connect with the app, I get a message Router Not Supported. If I try to Connect With Anywhere Access I get a message Green Dot RBR850 Connected Via Anywhere Access Serial #: -------- Device is offline. However the Mess WiFi is working well. Ran several tests with iPhone Speedtest and getting good numbers.
What App supports the RBR850?
No RepliesBe the first to reply
