Tartufone
Nov 17, 2020Aspirant
RBS40V no aggiornamento firmware
I have an Orbi RBR50 V2.5.2.4 Router with Orbi RBS40V V2.5.1.6. The RBS40V cannot update the firmware I also tried manually (with firmware https://www.downloads.netgear.com/files/GDC/RBS40V/RBS40V...
Tartufone
Updating on the satellite's login page
Nov 17, 2020Guru - Experienced User
photos don't show until a moderator approves them
- TartufoneNov 17, 2020Aspirant
sorry
the message: Firmware upgrade failed. Please check your file.
tank you
- plemansNov 17, 2020Guru - Experienced User
there's 2 versions of the rbs40v. make sure you select the correct one from the drop down.
Also, make sure you extract the file.
also, there firmware for when its running in orbi mode and firmware for extender mode. Make sure you download the correct one for what mode you're using it in.
