Gibbous
Oct 28, 2020Tutor
RBW30 Latest Firmware file corrupt
RBW30 Latest Firmware file corrupt!! 2.6.1.6 Broken .chk file instead of upgrade image.
- Oct 28, 2020
It can be a .chk file or .img file.
Oct 28, 2020Guru - Experienced User
indygadgetguy
Nov 27, 2020Aspirant
Sorry, I'm not able to upload the .chk file. The GUI says the firmware must be an .img file.
- antinodeNov 27, 2020Guru
> [...] I'm not able to upload the .chk file. The GUI says the firmware
> must be an .img file.Did you read any of the material above in this old thread which you
have (inappropriately) joined? Which part of the following was
unclear?:[...] starting your own new thread for your own problem is usually
a better idea than joining an old thread which has been marked as
"Solved".And which part of the paragraph which began as follows was unclear?:
"unable" is not a useful problem description. [...]
_Which_ "the .chk file"? To what were you trying to upload it?
- indygadgetguyNov 27, 2020Aspirant
1. Yes, I did read the material.
2. Sorry about "inappropriately" joining a thread. This forum sofware suggested I do that.
3. Apparently, my image didn't get attached, which answered your questions. It appears one of my browser extensions intefered with the upload of the image.
I'll see help elsewhere.
