Gibbous
Oct 28, 2020Tutor
RBW30 Latest Firmware file corrupt
RBW30 Latest Firmware file corrupt!! 2.6.1.6 Broken .chk file instead of upgrade image.
- Oct 28, 2020
It can be a .chk file or .img file.
indygadgetguy
Nov 27, 2020Aspirant
Sorry, I'm not able to upload the .chk file. The GUI says the firmware must be an .img file.
antinode
Nov 27, 2020Guru
> [...] I'm not able to upload the .chk file. The GUI says the firmware
Did you read any of the material above in this old thread which you
have (inappropriately) joined? Which part of the following was
unclear?:
[...] starting your own new thread for your own problem is usually
a better idea than joining an old thread which has been marked as
"Solved".
And which part of the paragraph which began as follows was unclear?:
"unable" is not a useful problem description. [...]
_Which_ "the .chk file"? To what were you trying to upload it?
- indygadgetguyNov 27, 2020Aspirant
1. Yes, I did read the material.
2. Sorry about "inappropriately" joining a thread. This forum sofware suggested I do that.
3. Apparently, my image didn't get attached, which answered your questions. It appears one of my browser extensions intefered with the upload of the image.
I'll see help elsewhere.
