airasel
Aug 19, 2019Aspirant
AC1200 R6220 Gigabit Router
Hello, Netgear team i need a troubleshoot. My Router is R6220 with latest version of firmware V1.1.0.86 installed, and it's connected to optical fibre modem C-DATA/ONU. My service provider is Ra...
DexterJB
Aug 21, 2019NETGEAR Moderator
Hi airasel, may we know how are you testing the speed separately for the YouTube and for regular browsing?
Dexter
airasel
Aug 22, 2019Aspirant
Hi DexterJB thanks for the reply, i can't test the speed separately, PC connect with Router then download from YouTube with IDM i get speed in seconds 2.537mbps to 2.570mbps thats mean line speed nearly 20Mbps, several times cancel or re-download attempt i get 6.276mbps to 6.396mbps nearly 48 to 50Mbps speed.
Without Router i get decent speed from YouTube with IDM 5 to 6Mbps in seconds nearly 50Mbps of speed when my provider check, after this test they told me my Router's getting old should bought a newer one.
