sunnyorlando
Jan 19, 2021Aspirant
Access Control not blocking Apple devices
I'm trying to figure out whats going on here with my issue. If this is not the right area, then can someone re-direct me to the right place or solution? I'd like to understand why is it that in a Wi...
schumaku
Jan 19, 2021Guru - Experienced User
To understand more how these extenders work, please also check (and post) we need also the extender table with the real MAC (used between the client and the and exender radio) and the virtual MAC (useed between the extender and the router radio) - ideally with some example clients connected.
sunnyorlando wrote:Thosie iPhones have been blocked several times, then they sho up with differnte MAC and automatically get connected without approvals.
That would be not allowed in fact. The access does work based on the MAC address only. Device name or the like does not matter.
sunnyorlando wrote:... by name, not MAC because it changes.
For a manged environment with MAC ACL, your known users must disable this "privacy" **** for your network (this is by all SSIDs offered) -> Use private Wi-Fi addresses in iOS 14, iPadOS 14, and watchOS 7 As you see, beyond of disabling the Private network feature for each SSID, Apple has not really a plan for people intending to use the (in my opinion mostly obsolete MAC security [as a bad guy, I am going to borrow one and wait till it disappears - easy possible with mobile devices]) in home or SMB environments - most have no managed MDM environments.
sunnyorlando wrote:And BTW - when connected, its to the main router (wireless3.2.4_OF), not the EXT. You can see the extender listed in the connected devices Image 1 at the bottom. So whatever the EXT functionality is, I don't see it affecting the rules of the main router if nto connected to the EXT. Right?
However you have named your router and extender radios - from the "wireless3.2.4_OF" name the name looks constructed of "wireless3" the "2.4" for a 2.4 GHz one, and then "_OF" why ever. If pairing a classic extender like yours would create a name like "wireless3.2.4_OF_EXT". How ever, why ever the networks were named or renamed - impossible to see form outside.
Login on the extender and check what is configured there.
sunnyorlando wrote:And an iPhone shows a wired??
And I don't get how that one IP that shows with 192 IP range. Its a 6c:B:CE MAC and it comes up as a Netgear product but I cant figure what it is, how is that getting a 192 when my private range is 172?
This could be directly related. The MAC address is the one from the extender, possibly this device had a different IP, probably it was wired to the router at some point. You can remove it from the list. Same for the Apple device showing up as wired.
Bottom line - managing MAC ACL is a pain in general. Managing the classic extenders with the MAC translation makes it more difficult. Allowing this privacy nonsense (you know oyur users, correct?) on your own managed network makes it simply impossible. and last, the unlucky requirement that all radois (connecting to the same network!) have to be configued on dedicaed names/SSIDs. Confusion complete for everyone.
sunnyorlando
>>> I renamed the network SSID - this should not be an issue. Or...? And why coudl it be...?
>>> The "_OF" is from the location of the router - Office.
>>> Yes, the extender automatically created teh SSID from teh router SSID and added the EXT
