BobFord
Mar 23, 2021Aspirant
Access Router RAX200 via Browser
My router IP is 192.168.1.1 but I can't access this through browsers (tried multiple browsers across multiple pc's) and even tried to delete browser history and use routerlogin.net and .com all don't...
Mar 23, 2021Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the router?
BobFord
The router is connected to a BT Modem connected to the broadband circuit
Version: 1.0.3.102
- plemansMar 23, 2021Guru - Experienced User
Which Bt Modem?
some have their own integrated routers which cause a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
disconnect the modem from the router, reboot the router, then try the routerlogin address
If that doesn't work, open a command prompt and type ipconfig
the default gateway would be the ip address.
- BobFordMar 23, 2021Aspirant
It's the Huawei EchoLife HG612
I'll reset the modem later when work is finished and report back
I've managed to connect in the past - that's how I setup the router in the 1st place
I may have to do a factory reset and see if that solves the problem
The EchoLife HG612 is a modem/router combo device. It causes a double nat.
it can also cause IP address conflicts.
Try putting the RAX200 in access point mode. Then look in the echolifes attached devices page (or equivelent) for the ip address for the RAX.
Or you could put the echolife in passthrough mode (if it has one) or put the netgears IP address into the echolifes DMZ.
With the 2nd 2 options, you'll probably need to change the netgears default ip address so it doesn't conflict with the echolifes
