jhpackard's avatar
jhpackard
Cannot connect to router WNDR3400v2/N600
- ASUS laptop - Win 7 - Latest router firmware   I  suddenly cannot connect wirelessly to the router. This followed a rerouting of power cords. The router failed to power up. After letting it sit...
  • wcalifas831's avatar
    wcalifas831
    Jun 26, 2017
    You can try and do a hard reset by pressing the pinhole with a paper clip for 30 seconds and re-doing your configuration. Also try a different power adapter if its having a power issue.
