zbrandom
Aug 12, 2021Aspirant
De-bricking EX6200V2 after failed firmware update
So out of the blue I decided to update my EX6200V2 firmware and for some reason the range extender died after the post-flash reboot. I tried resetting it but it doesn't work and I also tried to the t...
- Aug 12, 2021
> [...] tried to the tftp guide here [...]
I'd use the command-line TFTP client program which comes with your
computer's OS. I'd expect better error messages that way, at least.https://community.netgear.com/t5/x/x/m-p/1622096#M102004
(For Windows: https://kb.netgear.com/000059634/ )
> [...] I can't get the tftp to connect. [...]
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error. By itself,
saying that you tried it doesn't say much. Especially when using a
command-line program, copy+paste is your friend.For example, I know nothing, but I wouldn't bet that an extender
would have the same default-when-crippled LAN IP address as a router.
("192.168.1.250", perhaps?) Timing of the "put" command in the
reset/start-up sequence might matter, too.
antinode
Aug 12, 2021Guru
