Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
antinode
Aug 05, 2021Guru
> [...] Is it possible to use a prior firmware version that did work?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
- WinancyAug 05, 2021Apprentice
antinode Thannk you so much for putting me in the right direction. I downloaded and installed the previous version 1.0.45. At frist, I was getting the same errors, then realized, I probably have to restart the computer. After I did that, everything is working just fine....so far. Fingers crossed! Now, I just wait for the next firmware update and hope it will behave.
Unfortunately, I spoke too soon.....
Not sure where to go from here....I downloaded and installed the previous firmware, which booted the router, then I restarted the computer, and it seemed to be ok for a few minutes and then the errors started all over again. Factory reset??? Ugh.
- WinancyAug 06, 2021ApprenticeUsing whatever the ISP provides.
I've shut down for the night, so I can't check until tomorrow.
But I did flush DNS and reset winsock again and all worked fine... For about 15 minutes, then it started all over again.
Haven't tried using a different DNS service. It should work with what I've been using for years, no?
- phenry9999Oct 03, 2021Tutor
Thank you for the info about getting previous versions. The link was there, I just never saw it :< until I read your message and explicitly did a FIND on the page. Thank you. I'm going to try, systematically the previous versions to find out which one works.
- mkxOct 03, 2021Tutor
Don't waste your time on that version.
I just tried 1.0.4.74 and things are....so far so good. Not sure if it'll have probelms in the coming hours\days, but I have the previous versions to try too if this one goes bust. Does anyone know which specific version the DNS_PROBE_FINISHED_NXDOMAIN started happening with?
