Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
Winancy
Aug 05, 2021Apprentice
Unfortunately, I spoke too soon.....
Not sure where to go from here....I downloaded and installed the previous firmware, which booted the router, then I restarted the computer, and it seemed to be ok for a few minutes and then the errors started all over again. Factory reset??? Ugh.
golfnut1969
Aug 29, 2021Guide
I tried switching to another DNS provider, but this didn't fix the issue either. I was using my ISP's DNS and switched to two others, but the same thing happened. This is definitly the router firmware.
- WinancyAug 29, 2021ApprenticeUPDATE
Netgear support called back yesterday to see how everything was going. I told her that everything was working great now because I bought a new router. She asked if it was a Netgear router and I told her no. She then said that the case is now closed, stay well and have a good day.
