Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
michaelkenward
Nov 07, 2021Guru - Experienced User
robjak wrote:
After testing over the past few hours, i have been getting a few DNS>PROBE_FINISHED_NXDOMAIN error.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
egc112
Nov 07, 2021Tutor
Netgear makes great routers, I installed a bunch of R6400, R7000 and R7800 but in the software departement there is definetely room for improvement (the new DUMAOS is a lot better) but luckily there are great third party firmwares available.
When I get a new Netgear router the first thing I do is to install something else like DDWRT :)
- michaelkenwardNov 07, 2021Guru - Experienced User
There has certainly been some"slippage" in quality recently. Worse, they take too long to mend things like the issue that kicked off this coversation.
Fortunately, the R7800 soldiers on without issues. It has even avoided some of the garbage that Netgear has foisted on other routers, like Circle and Armor which seem to be designed to take your money away.
Hardware with DumaOS is expensive!
- WinancyNov 07, 2021ApprenticeI said BLEEP Netgear long ago, when after two days of tech support finally telling me that it was not the router, but my ISP. I don't know how the rest of you have tolerated 3 months of this!
