Winancy
Aug 03, 2021Apprentice
DNS>PROBE_FINISHED_NXDOMAIN error since latest update
Model R6400, firmware v1.0.1.74_1.0.48, Windows 10, ethernet connection Since I updated the firmware, I have been getting DNS_PROBE_FINISHED_NXDOMAIN errors when I open up browsers and go to webpage...
itnewng
Feb 11, 2022Aspirant
I am also run into the same issue of the following router
Nighthawk X6 AC3200 Smart WiFi Router (R8000)
Serial Number: 3W74487H03B4D
Previous Firmware Version
V1.0.4.28_10.1.54
Current Firmware Version (Updated on 02/01/2022)
V1.0.4.76_10.1.82
Could someone suggest which FW version to downgrade in order to fix this issue?
Thank you,
Winancy
Feb 11, 2022Apprentice
Do yourself a favor and throw your Netgear router in the garbage and go out and buy a different brand. It's been 6 months and Netgear hasn't done anything to correct the issue other than tell you to turn off your virus protection contact your ISP and tell them they have a DNS issue.
- michaelkenwardFeb 12, 2022Guru - Experienced User
Winancy wrote:
....Netgear hasn't done anything to correct the issue other than tell you to turn off your virus protection contact your ISP and tell them they have a DNS issue.Where did you read that?
It isn't the usual response to that problem.
Roll back to older firmware works for most people.
- WinancyFeb 12, 2022Apprenticemichaelkenward
I didn't read it anywhere. That's what Netgear support told me after several days of "try this" and "try that." I'm the person who started this thread. Scroll to the beginning to read the whole saga. Rolling back didn't work.- michaelkenwardFeb 12, 2022Guru - Experienced User
Winancy wrote:
I didn't read it anywhere. That's what Netgear support told me after several days of "try this" and "try that." I'm the person who started this thread. Scroll to the beginning to read the whole saga.A lot has changed since 2021-08-03, near on six months ago. (That's history.)
Even Netgear probably knows by now that whoever you contacted back then was wrong.
Much better to work on what we know now.
Rolling back didn't work.It did for many people. That should be a cue to dig deeper into what is happening at our end.
Did you get anywhere? (Forgive me if I don't re-read all of the past 168 messages..)
