jored
Apr 16, 2016Aspirant
Error 503 : Service Temporarily Unavailable
Hi All - I receive this "Error 503 : Service Temporarily Unavailable" message in all browsers when I try to reach a specific site through the router (wireless or wired). When I bypass the route...
- May 07, 2016
Hi. I finally got around to resetting the router to factory settings, but the issue still exists when connecting through the router. I'll connect to the site via mobile network when I need to.
I appreciate the assistance.
jored
Apr 22, 2016Aspirant
Hi. I tried lowering the MTU, but that didn't fix it. The 503 message still comes up just for that site.
- ElaineMApr 25, 2016NETGEAR Employee Retired
It's working fine on my end.
Perhaps, you may need to factory reset the router.
Resetting the router will wipe out all the settings and it will need to reconfiguration to get back the internet access.
To reset the router, push the reset hole at the back of it for 10 seconds by using a paperclip.
After reset, reconfigure the router as if it's brand new out of the box. Or you may see this article on how configure the router.
- joredMay 07, 2016Aspirant
- ElaineMMay 27, 2016NETGEAR Employee Retired
You're very welcome.
Perhaps something in your network is preventing you from accessing it.
