sandokanfirst
Mar 31, 2021Guide
Error DNS_PROBE_FINISHED_NXDOMAIN after update to V1.0.1.70_1.0.44 of firmware
Hi all, Ever since I have updated my AC1750 R6400 router every other site I try to open gives a DNS_PROBE_FINISHED_NXDOMAIN error. If I refresh (F5), the website in question usually opens. It's a bi...
benhase
Aug 23, 2021Initiate
The R6300v2 Firmware Version 1.0.4.52 has the same DNS_PROBE issue. I did not try the 1.0.4.50 level. I went back to my previous Firmware Version V1.0.4.46_10.0.93 and the issue went away. Hopefully Netgear will fix this huge issue in their later firmware levels.
fram45trim
Nov 23, 2021Initiate
I have the same problem, upgraded to latest firmware yesterday constantly need to refresh page to eliminate "page cannot be found error." Using VPN resolves the issue. Considering going back to previous firmware version, but not sure how to find.
- plemansNov 23, 2021Guru - Experienced User
Did you try enabling IPv6?
- fram45trimNov 23, 2021Initiate
Thank you for the suggestion. I had not enabled before, but when I went back to enable and read the process of doing so in the manual, it occured to me that I never reran the setup wizard after changing data suppliers earlier in the year. I reran the wizard and at least for the time being the problem seems to be resolved. After testing I also enabled IPv6 in the auto config mode. Thanks again
Glad to hear it worked for you!
- michaelkenwardNov 24, 2021Guru - Experienced User
fram45trim wrote:
....when I went back to enable and read the process of doing so in the manual, it occured to me that I never reran the setup wizard after changing data suppliers earlier in the year.
You did well to make that move. Well done. A lot of people don't.
Changing ISP is just one event that needs a reset of the router. Your experience suggests that running the wizard achieves the same thing as a reset.
The old service, or an old modem, will create various settings on your router. Change the stuff in front of it, and you need to wipe out those settings and create new ones for the new network.
