Mph3842
May 28, 2021Aspirant
I have an R6400 and want to connect a HDD via USB as a NAS drive
I have a Nighthawk R6400 router and have a HDD connected to it via its USB port. I want to set up Readycloud but cannot seem to do it. Advice please?
antinode
Jun 01, 2021Guru
> I have a Nighthawk R6400 router [...]
R6400[v1] or R6400v2? Look for "Model" on the product label.
Firmware version?
> [...] When I look at the Netgear Router page, under Readyshare, the
> Readycloud button does not appear (see photo). [...]
I don't trust Netgear router firmware with my stored data, so I don't
use this stuff, so I don't pay close attention, but I got the impression
from my readings here that Netgear was dropping (had dropped?)
ReadyCLOUD support from recent firmware versions on some (all?) its
routers. This could be an artifact of my usual false-memory syndrome,
but, if you loaded an older firmware version and the feature reappeared,
then that would be suggestive. I'm too lazy to scan all the firmware
release notes to see if anything relevant could be found that way.
> [...] By convention NAS usually means Ethernet. That's not USB.
Sigh. "By convention", in this context, NAS means Network-Attached
Storage.
https://en.wikipedia.org/wiki/Network-attached_storage
A purpose-built NAS server typically uses a high-speed interface
(Fibre Channel, SCSI, SAS, SATA, ...) to communicate with its storage
devices (disks, et al.), and an Ethernet or other network interface to
communicate with its client devices.
Some router models offer some NAS capability using a USB interface to
a storage device, and the usual Ethernet interface for communication
with a client. That is what's being discussed here.
Some of the participants in these forums seem to believe (and enjoy
telling others) that "NAS" means a box whose label says "NAS", rather
than a gizmo which attaches a storage device to a network.
Others believe that any gizmo which attaches a storage device, even a
USB-connected storage device, to a network, like, say, a Netgear
R6400[vX], constitutes network-attached storage (NAS). I have no
trouble with this functional definition (because I can read), but some
people seem to, which leads to "help" like:
A USB-connected disk, by itself, is not (normally) NAS. A
USB-connected disk, when connected to a computer with the right
programming (and a network interface), can be, literally, exactly,
network-attached storage.
But I don't expect to persuade the local "experts".
It's true that a purpose-built NAS server which does not use USB as
its storage interface will typically have faster hardware, and
software/firmware which is more reliable and has more features (like
RAID, for example) than a consumer-grade Netgear router-as-NAS. But,
network-attached storage is still network-attached storage. For some of
us, at least.
Mph3842
Jun 01, 2021Aspirant
Thank you for your response. I agree with you that a USB attached drive is NOT the same as an NAS drive. All I want to do is to be able to upload my photos from my phone to the USB drive since Gogle Photos is now limiting space. If you can suggest a way for me to do that I would be appreciative. The upload need not be automatic as I do not mind uploading them once a week by myself but what I do want to do it to be able to uload them (or view them) from anywhere. Thanks in advance.
M
- antinodeJun 01, 2021Guru
> [...] All I want to do is to be able to upload my photos from my phone
> to the USB drive since Gogle Photos is now limiting space. [...]You seem to want plain-old ReadySHARE (LAN access to the shared
storage), not ReadyCLOUD (outside-world access to the shared storage).If your actual complaint is that the "8TB Seagate Hub Plus" is not
appearing under "Available Network Folders", then that's not a
ReadyCLOUD problem.> [...] what I do want to do it to be able to uload them (or view them)
> from anywhere. [...]So, "All" was not really "all"?
_That_ would be a ReadyCLOUD problem. If that feature's not in the
current firmware, then I'd investigate older/different firmware.
> Firmware version?Still wondering.
To deal with the empty list of "Available Network Folders"...
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for "USB
Storage Device Requirements". Find the list of supported file system
types. Note that exFAT is not among them.What is the file system on your "8TB Seagate Hub Plus"? If it's not
one of the supported file systems, then you might want to format it
appropriately. (NTFS is popular.)
> Readyshare is very picky about the USB drives it will accept. 8TB is
> too big for most devices. [...]
I'd try it with a supported file system before abandoning all hope of
using the whole thing. - michaelkenwardJun 02, 2021Guru - Experienced User
Congratulations. You have made the right first decision. Too many people leave important photos on their phones and then wonder why they all disappear when they lose their phones.
The best strategy probably depends on the phone. I use cameras rather than phones, but the same thing works. I can set up the cameras to copy photos over wifi, but I find that it is better just to use a USB link to a PC and then copy everything from there.
But that raises the first question, you have a USB drive attached to the R6400. Is there also a PC in there?
If so, I would be tempted simply to copy the photos from the phone to the USB drive using the PC as an intermediary.
I also use ReadySHARE to copy the photos on to a USB drive. (I like to have more than one copy.) I even use ReadyCLOUD to get at them.
Despite recent claims from Netgear that it is killing the service, ReadyCLOUD still works. I have more than 20 years of photos on a 2TB USB drive.
I can't see that I will ever get 8TB of storage for photos. If you look at the USB compatibility page I linked to earlier, you will see that there are plenty of 4TB drives that work with the R6400. Get one of those and it should work fine with ReadySHARE and ReadyCLOUD.
- Mph3842Jun 04, 2021Aspirant
I am seeking a home grown solution to replace Google photos without the expense of a synology NAS set up. I will try a smaller USB drive. Thanks
- antinodeJun 05, 2021Guru
> [...] I will try a smaller USB drive. [...]
Do you expect that to restore a ReadyCLOUD control to the BASIC >
ReadySHARE page in your router's management web site? I don't.I'd expect the results from a smaller drive with an incompatible file
system to be very similar to the results from a larger drive with an
incompatible file system.Of course, with my weak psychic powers, I don't know which file
system is on your "an 8TB Seagate Hub Plus", but one of us might be able
to find out by connecting it to some computer or other. It's possible
that 8TB is too big for your router firmware, but that's not the only
possible problem.Is "an 8TB Seagate Hub Plus" anything like an "8TB Seagate Backup
Plus Hub"?
