LoadedferActon_
Nov 22, 2020Follower
re: old router
Hello All, I used a Netgear N750 Dual Band Router, Model WNDR4300V2. Now I've changed it for a new one. Is the old one safe to recycle, sale, or should I just trash? Don't want any possible sec...
michaelkenward
Nov 23, 2020Guru - Experienced User
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
That will eliminuate any personal details.
wcalifas
Nov 24, 2020Prodigy
If it still works you can list it on ebay. You can reset it by pressing the reset button for 30 seconds with a paper clip and it will go back to default settings. List it on ebay and sell it for cheap maybe someone can use it if its still good.
