GreyBeard1948
Mar 27, 2021Aspirant
Orbi RBS40V. Netgear sent firmware update
I have an Orbi Rbr50 WiFi router with 2 satellites. One of the satellites is an Orbi Voice rbs40v. Netgear sent an email to upgrade the rbs40v but every time I try to update the firmware I get an erro...
- Mar 29, 2021
You are on the current firmware version.
I know that there was issues over the last few days with the auto-update server but you're on the most current so you should be good.
Mar 29, 2021Guru - Experienced User
GreyBeard1948
Apr 07, 2021Aspirant
Can someone tell me why when I try seeing if I have an update on my Orbi application I get an error message and not the message that your system is up to date? I do not understand what would cause this ad I have an excellent WiFi signal.
Thank you
Thank you
