wimS's avatar
wimS
Power (& Internet LED) - Solid Amber
Hi, For several years I've used my Netgear router as Access Point. This worked great. A few days ago I moved the Netgear to another room, and since then it does not work anymore. The Power LED ...
  • wimS's avatar
    wimS
    Jun 21, 2018
    Since I was not able to get it working, I went back to the shop, which concluded that the device was broken. So I bought another one.
    Thanks for your kind support.
    -wim
