rltorson
May 10, 2018Tutor
Printer Won't Connect to Network
For over two years I have been using my printer (HP Photosmart 2610Xi) connected to the router via a LAN port on the router as this allows me, using the NetgearGenie Air Print feature to print using ...
- May 13, 2018
Got it going. Trick was to reset printer to factory default, open System Preferences and delete the printer then re-install it then open Netgear Genie and reselect the printer in Air Print. Now I can (again) print from my iPhone or iPad even using my antique non-airprint printer
rltorson
May 12, 2018Tutor
1. Yes, of course the input to the SB 6141 modem is a coax. Sorry I am having trouble with my nomenclature.
2.I did not change the config of the WNDR4300 router
3. OK, I will give up on using a USB cable to connect the printer to the router.
4. When I put the new modem in place I changed nothing. And everything but the printer worked fine. By now though I have changed everytging several times.
5. I was not using ReadyShare before and would be happy to not use it now.
6. I thought the ethernet cable between router and printer might be the problem so tried another, with the same result (printer not connected)
7. Web searches are indeed helpful sometimes, this does not appear to be one of those times, especially with my dyslexia.
rltorson
May 12, 2018Tutor
Finally some progress! I Opened the Mac's System Preferences and deleted the printer. Then reinstalled it. Now the Mac can print when the ethernet cable is connecting the router to the printer.
Still need to be able to use the Netgear AirPrint function.
When I try to print from my iPhone it act like its going to print and gets as far as "Trying to contact Printer then stops until timeout.
