Jan 30, 2022Guru - Experienced User
Re: R5120 and WAN port
You're correct in that the R6120 will be the bottleneck in the system as it won't perform any faster than the 100mbps.
You'll want to upgrade to a gigabit device.
With 600mbps, I'd look at a de...
DonW0572
Jan 30, 2022Tutor
Upping my home service to 600mbps. WAN port on 6120 is rated 10/100. I would not think a gig output port on new modem will connect to 10/100 as expected.. Would a new modem/wi-fi router be better choice? Current modem will not support beyond 300mbps, so upgraded modem is the likelihood. Looking at options for a combo if the 6120 will not give the increased speed. ISP is sending a modem on a 12 month free plan, but I do not intend to pay monthly fee after that, hence purchase. Will certainly test with the supplied modem when received, but willing to invest in new hardware if that's the best option.
microchip8
Jan 30, 2022Master
you need a new modem *and* a new router. Some people go for a gateway (modem+router in one) but I prefer to keep things separate. If you go for a modem-only and a router, check with the ISP which modem models they support
