Jan 30, 2022Guru - Experienced User
Re: R5120 and WAN port
You're correct in that the R6120 will be the bottleneck in the system as it won't perform any faster than the 100mbps.
You'll want to upgrade to a gigabit device.
With 600mbps, I'd look at a de...
Jan 31, 2022Guru - Experienced User
Manually install it. They use different hardware and it can cause issues/brick your device.
DonW0572
Jan 31, 2022Tutor
Thx. Will do. Ordered the 6700 this morning, and a high speed Motorola modem, which actually went on discount since yesterday. Will have them tomorrow.
