Mamacom
Sep 24, 2017Aspirant
R6400 WiFi not working
My WiFi calling used to work with previous router (Motorola) I have Netgear R6400 on Comcast Firmware Version V1.0.1.24_1.0.18 WiFi it self works great. My Phone is Sprint LG Stilus The WiFi c...
- Sep 24, 2017
Found the solution on the web...and it works for me :)
You must enable IPSec Passthrough on the NAT Passthrough tab in the WAN section.
In english....
Go to Advanced ..
WAN setup..
Last line NAT filtering
Switch it from Secured to Open !
Why would Netgear have it on Secured whereby blocking WiFi calling in their Factory set up is a mistery to me.
Mamacom
In english....
Go to Advanced ..
WAN setup..
- michaelkenwardSep 24, 2017Guru - Experienced User
Is "wifi calling" using wifi instead of your mobile service?
I can't find this in my stash of Netgear manuals. Maybe it is a new concept to Netgear. It does not seem to be something that all phones can do.
- MamacomSep 24, 2017Aspirant
michaelkenward wrote:Is "wifi calling" using wifi instead of your mobile service?
I do not know, not an expert,
but as soon I switched the NAT from Secured to Open, it works on my Sprint LG phone. It has a separte WiFi On/Off, and that one was working.
The WiFi calling is also a On/Off but was not working
I think is is using purely WiFi signal not Sprint phone network for WiFi calling.
