Qstik
Jan 17, 2022Guide
Re: R6700v3 Firmware update V1.0.4.122_10.0.95 problem
Model R6400v2 Windows 10 Home and Windows 7 Pro (all latest updates on both) I had all the same issues as mentioned above with the exception that I initially tried updating firmware through the...
DexterJB
Feb 28, 2022NETGEAR Moderator
Hi Qstik, we'd like to know the following:
What prompted you to use the TFTP method instead of the usual manual/auto update method?
Have you tried updating to the latest firmware version (1.0.4.126)?
What is the status of the power LED?
Dexter
NETGEAR Team
Qstik
Feb 28, 2022Guide
Hi DexterJB
I was locked out of the web interface following a manual update. I don't know how else to reflash new firmware or revert to old firmware (not my preferred option).
I have not tried the new firmware. I do not remember the status of the power LED.
I have replaced my Netgear router with a different brand, which is working just fine.
Qstik
