GreyBeard1948
Apr 08, 2021Aspirant
Rbr50 and two satellites
Whenever I try to see if there are any firmware updates I get an error message instead of the message stating your firmware is up to date. Any suggestions as to why I keep getting the error message. I...
paulhiggs
Apr 15, 2021Aspirant
I have the same problem.
My RBR850 and satellites did an update using the web page "Firmware update" once to get to 3.2.17.12
Every week or so, I would "check for new updates" and be advised that no new firmware is available, however checking https://www.netgear.com/support/product/rbk853.aspx#download I found V3.2.18.1_1.4.14. I downloaded both versions (router and satellite) and did a manual update.
GreyBeard1948
When I try to see if there is a firmware update after about 2-3 minutes it says encountered firmware error. Try again or skip. It always used to say no firmware found or new firmware is available. Not sure how to handle this problem.
