nordman
Oct 09, 2018Tutor
ReadySHARE USB Printer broken after updating to OSX 10.14 Mojave
I upgraded my macbook pro to OSX 10.14 Mojave and now I can't get Readyshare USB Printer to work. I keep getting the same error that it could not complete installation. It previously worked on 10.13....
- Dec 20, 2018
Hi community,
I have had the same porblem but get it solved yesterday. In the web I have found following:
"Fixed it by:
1. Uninstall the Control Center app
2. Mac System Preferences > Printers&Scanners > Reset Print System (remove your printer by pressing the "-")
3. Reboot
Now Mac OS Mojave (Mac System Preferences > Printers&Scanners >"+") recognizes printer networked through Netgear router.
It works.
michaelkenward
Nov 05, 2018Guru - Experienced User
stephenx wrote:
Tech guys should really look into this.
Which tech guys do you have in mind? Apple? They broke it. Have you asked them to fix things?
Apple is famously tight lipped and closed in its technology. If it keeps things secret, then there isn't much that other companies can do.
bluzfanmr1
Nov 08, 2018Tutor
Same thing happened with High Sierra (lots of forum posts on here). It took forever for Netgear to update the USB Control Center software.
- DekWatsonDec 04, 2018Aspirant
Same issue here, just setup Orbi network and then added printer...
- phazeiDec 13, 2018Initiate
Same here :smileymad:
- HaptDec 20, 2018Initiate
Hi community,
"Fixed it by:
3. Reboot
It works.
