Pablo777
Sep 13, 2021Tutor
Router Problem with WIFI
Pablo777 Novice 2021-09-13 10:16 AM I have Internet using Cat 5 cable but my other wireless divices like cell phones and TV's say:"Connected, no Internet. Ple...
- Sep 16, 2021
I bought a new router R6850 AC2000 and installed it correctly and all is well now. Thank you for your help.
Sep 13, 2021Guru - Experienced User
Seems like we're running into a lot more issues lately with users of broadcast internet.
Not sure if its because of more companies using it or what.
If you connect a simple unmanaged switch to their box, are you able to connect mulitple devices ?
Pablo777
Sep 13, 2021Tutor
I did a factory reset and setup the router. Now all works except some iPhones and one laptop. Any ideas? I bought a R6850 AC2000 today and if we can't get the R6400 AC1750 working properly, we will replace it with the new one.
- plemansSep 14, 2021Guru - Experienced User
Does it work if you put the netgear in access point mode?
If it doesn't, factory reset will get you back to stock settings.
Just checking to see if your ISP has any NAT running on their setup.
- michaelkenwardSep 14, 2021Guru - Experienced User
That suggests very strongly that the problems are with the iPhones and one laptop. Wifi is a two-way process. Both parts have to cooperate.
Tried telling them to forget the wifi connection and creating it again from scratch?
- Pablo777Sep 16, 2021Tutor
