floriann
Apr 27, 2014Aspirant
Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround
Hi! Some days ago I bought the new Netgear Trek PR2000 mobile wireless router. Purpose was to have an AP for all my devices while traveling and being able to connect them to a hotspot or hotel wifi...
- Mar 22, 2016
hksteve I would like to inform you that the fix is now available in our download page.
Feel free to update your firmware and provide feedback.
Thanks!
ElaineM
Mar 07, 2016NETGEAR Employee Retired
Port 23 is open on the LAN side designed for our telnetable tool.
Glad to hear that the firmware helped solved your concerns.
BARNES
Mar 07, 2016Apprentice
Indeed it has, and thank you again Elaine for the help...
To those having the reboot issue with the PR2000 Trek, should contact support ASAP and get that Beta .15 firmware! Mine has been running flawless all weekend, aside from a little performance tuning needed, offers a really good compromise with size. Those who expect dual core AC performance don't fully understand what compromise means even though everything in our lives is a compromise. They had a saying when it came to engineering; Speed, Cost, Quality - Pick two...
Peace out...
