kanakakai
Sep 14, 2025Aspirant
Unable to access my router...
I have a WNDR3700v3 router. I am direct connected to it. i am unable to access my router using: routerlogin.net routerlogin.com http://192.168.1.1 http://192.168.0.1 I have deleted web c...
DarrenM
Sep 15, 2025Sr. NETGEAR Moderator
Do you have another router connected to the network? If so, it might be assigning the WNDR3700 a different IP address. If you need to connect to that router's GUI and look at the connected devices, and then use the IP address it assigned to the router in the web browser. You may also want to try 192.168.100.1
Thanks
DarrenM
