Aprilbrown
Dec 05, 2017Aspirant
WNDR3400 v3
I am trying to link a mini google system to my router. It's states cannot find. I was told it's not compatible. My internet provided suggest I try here. Thanks.
- Dec 07, 2017
https://www.netgear.com/support/product/WNDR3400v3.aspx#Firmware%20Version%201.0.1.14
Here is the firmware update for your router in the above link the release notes are dated this year may help.
Can't hurt the nonconnection of the mini google devices any more then it is .
William10a
Dec 07, 2017Master
- AprilbrownDec 07, 2017Aspirant
Thanks I will try this
